| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I have a '54 chevy 4 speed trans I got for almost nothing, but the gear shift lever is missing. There is a junk truck on a friends farm that is rotted away gone, total trash almost but the trans is in it, but it's up on a hill, can't get to it etc. I just want to get the gear shift lever. how does it come out?
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You push down on the tower cap and rotate it slightly counter clockwise. It will then release. The shop manual shows a tool. I use a mokey wrench on its side. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Push down on retainer and turn ...pic... ...click... I think it's ccw Junkyard.... might need some penetrating oil to loosen up the retainer | | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | counterclockwise then lift it up I guess? Thanks!!!Can I use a crescent wrench on it'side?
| | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | HOLY COW! that video clip is perfect. Thanks guys!! this site is awesome! I am trying to make my own side by side out of my extra 248 I6, my 4 speed, and one of my extra rears, and my extra steering column......... It will be one tough mule (if I actually get it made.
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | when I took mine apart for inspection, I used a roll of electrical tape, slid it down the shaft, pushed and turned ccw. worked like a charm cause the cardboard middle of the tape roll kinda 'gripped' onto the retainer. | | |
