0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | Okay So I know that the Primary lining is the shorter lining and always goes towards the front of the wheel or truck. I know the Secondary lining is the longer lining and always goes towards the rear of the wheel or truck. Here is the question: which way do the adjusting stars face? I know the right side star is next to one shoe while the left side faces the other, I just can't remember which is which? I want to make sure my brakes were put on properly, thanks guys! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Someone will post the clear/correct answer.
The practical answer is to orient the adjuster star so that you can adjust through the hole in the backing plate. You can make this decision "by eye" when you put the shoes on.
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | If I remember correctly, my adjustment stars are towards the rear brake pad. I'm not saying mine is correct, ,thats just how it is and it seems to work for me! | | |
