6 members (Gdads51, King Kielbasa, Otto Skorzeny, Robert Crandall, cmayna, JoergK.), 85 guests, and 5 robots.
Topics128,181
Posts1,057,152
Members48,464
Okay So I know that the Primary lining is the shorter lining and always goes towards the front of the wheel or truck. I know the Secondary lining is the longer lining and always goes towards the rear of the wheel or truck. Here is the question: which way do the adjusting stars face? I know the right side star is next to one shoe while the left side faces the other, I just can't remember which is which? I want to make sure my brakes were put on properly, thanks guys!
Someone will post the clear/correct answer.
The practical answer is to orient the adjuster star so that you can adjust through the hole in the backing plate. You can make this decision "by eye" when you put the shoes on.
If I remember correctly, my adjustment stars are towards the rear brake pad. I'm not saying mine is correct, ,thats just how it is and it seems to work for me!
