2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi,
To hopefully avoid the Summit Racing buy/return/buy another one/return routine I have been in lately, can anyone tell me what cover to buy for a newer (1996) SBC connected to the original SM420 Muncie 4 speed on my 56? Is it 2 piece or 1 piece? My preference is for plain stamped steel that I can paint. Thanks! | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | The original '56 V8 truck bellhousing uses a 2-piece cover. The vertical cover piece has a hole in it allowing the starter to pass through. Mike B  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Grandpa's 56, the proper cover would depend more on which bellhousing you're using rather than the age of the small block it's bolted to. The older cast iron bellhousings used two pieces a vertical piece that has a hole for the starter to pass through that Mike B mentioned, the other piece is a 1/8 circle that bolts to the flat bottom surface of the bellhousing, hope that helps. | | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi,
The bellhousing # is 3815891, original to a 63-66 truck. Is a wrecking yard my best bet for the covers?
Thanks. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Grandpa's 56, yes the wrecking yards or post an ad in the parts wanted column farther down the page on this site, hope that helps. | | |
