2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
Hi,
To hopefully avoid the Summit Racing buy/return/buy another one/return routine I have been in lately, can anyone tell me what cover to buy for a newer (1996) SBC connected to the original SM420 Muncie 4 speed on my 56? Is it 2 piece or 1 piece? My preference is for plain stamped steel that I can paint. Thanks!
The original '56 V8 truck bellhousing uses a 2-piece cover. The vertical cover piece has a hole in it allowing the starter to pass through.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B Offline
Hy Grandpa's 56, the proper cover would depend more on which bellhousing you're using rather than the age of the small block it's bolted to. The older cast iron bellhousings used two pieces a vertical piece that has a hole for the starter to pass through that Mike B mentioned, the other piece is a 1/8 circle that bolts to the flat bottom surface of the bellhousing, hope that helps.
Hi,
The bellhousing # is 3815891, original to a 63-66 truck. Is a wrecking yard my best bet for the covers?
Thanks.
3B Offline
Hy Grandpa's 56, yes the wrecking yards or post an ad in the parts wanted column farther down the page on this site, hope that helps.
