2 members (66flea, Phak1),
115
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Getting ready to put the weatherstrip around the outside of the doors on my 49 AD. The higher side of the weatherstrip goes toward the outside, correct? | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I asked a similar question on the GMC forum and here is the answer I got: The taller rib should be laying against the body of the door and the short rib should make contact with the truck body when the door is closed. The square side is against the door and the valley goes toward the truck when the door is closed. Cecil.... | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | The taller crown should sit at the OUTER edge of the door. See This ... scroll down to the last picture ... I think you can see what I mean there.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Are you sure of this Alan? From what I understand, it is just the opposite. The short rib should be on the outside. At least this is what a couple of other people have told me. Cecil.... | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I did mine like Alan's and it's working fine - no whistles or leaks. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What Alan describes (and displays very nicely on his website) is what is also shown in drawings in the Factory Assembly Manual (Section: 1; Sheet 17; and Section 1; Sheet 20.00).
Many people buy a kit from Chevy Duty (good price - good quality). The two kits that I bought had a copy of a copy of a copy of a drawing of the weatherstrip in the opposite orientation than that shown in the Factory Assembly Manual.
I installed the weatherstrip as described by Alan (and the Factory Assembly Manual) and had no problems.
Tim | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I can't swear that it's the "correct" way ... I don't remember where I originally got my info from about that ... but I do know I research things well before I go ahead; I was sure that was the correct way when I did it; and everything works great, so I'm 99.9% sure this is the way.
Also, since the idea is to create some compression between the rubber and the door-frame when the door is closed, it sure doesn't make sense to "hide" the crown by tucking it into the corner where it can not compress.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | Followup. Did one door last night and the other tonight. Used horvath's high side out method with Chevy Duty weatherstrip. I put the adhesive on the door using a small disposable brush, the kind you use for solder flux, perfect width plus long enough to do the front around the hinges, plus they come two to a pack so one for each door. doors close about as easily as without the weatherstrip. thanks to all who posted. | | |
