Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (wvstovebolt), 31 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#1047393 08/06/2014 5:06 AM
Im running a 235 out of a 62 Impala in my 49 pickup. Starts great every time Idles fine when cold but as temp starts to rise my idle speed starts to slow down, while driving if I come to a stop sign or red light it will completely die, I hit the starter button an it starts just fine but as soon as I take my foot off the gas it dies. I am running the stock Rochester one barrel. Do I need to get a carb kit an see if that helps or do I need to start looking for a new carb, if so any recommendations for a new carb? Thanks for any advice you guys can give me.
red49 #1047401 08/06/2014 5:46 AM
Is it an old problem or a recent engine swap?
Hollow65 #1047402 08/06/2014 5:50 AM
It is a recent engine swap, Carb came with engine
red49 #1047404 08/06/2014 5:56 AM
Definitely rebuild and if it still persist then swap carbs. Rebuilds are cheap and easy. How close is the fuel line to a heat source? Maybe it's boiling off at idle?
red49 #1047425 08/06/2014 12:40 PM
V
V Offline
Before you go too deep try properly adjusting the carb w/the engine warmed up to operating temp.
If you have a vacuum gauge, connect it to the manifold vacuum port and adjust the fuel/air mixture and idle speed to get the highest steadiest reading at idle.
IF the above doesn't correct it test for a vacuum leak at the carb, where it bolts to the manifold and where the manifold bolts to the head.
Assuming you have an automatic choke, your symptoms sound like a vacuum leak, i.e. as the choke opens the fuel/air mixture leans out and a vacuum leak will make the idle mixture too lean to idle.
Course when you don't know the history of a carb a rebuild is a wise move.
Good luck
Dave
