1 members (1 invisible), 65 guests, and 0 robots.
Topics128,049
Posts1,055,740
#1047182 08/05/2014 4:20 PM
Guys,
I used black DTM Epoxy Primer on my disassembled Cab and would have used reducer with it for the sealer... only, I ran out of the primer before I could get to that stage.
The Primer is Kustom Shop from TCP Global.
Question is, should I order some more of the same brand or can I use a different brand for the sealer?
Thanks in advance!
A different brand would probably work, but I wouldn't recommend it.
I would talk to your supplier.
Because it's epoxy you are going over, I think you will be fine switching brands. I don't worry about brand matching epoxy primer/sealers with finish coat. I do try to match brands on base/clear or lacquer primer/finish coat.
I used PPG epoxy primer on my 37 and switched to DuPont for the regular primer & top coats with no problems. I had to switch as my local PPG dealer went out of business. The DuPont dealer told me there would be no problem & I haven't noticed any.
1937 Chevy pickup
1952 MGTD
Mr W
The rule of thumb with epoxy is you can cover it with just about anything. You should check your tech sheet to rule out anything specific otherwise do what you need to do.
Good luck
36 Chevy 1.5 ton - rusting away
52 Chevy 3100 - in progress
72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
Thanks for the responses guys!
I ordered the same brand to be safe (before reading all the response posts).
It delayed me a couple of days but at least I finished the project before the weekend was over and I don't have to worry about it (brand mixing).
I really did underestimate how much primer and paint I would need to paint the truck!
