0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | would it be possible to put a 1966 pickup fron suspension on a 1955 panel?.i am asking be cause I have both.i plan on keeping the panel and scrapping the pickup. thank for all of your help .. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | things will be different on 55 1st series vs 55 2nd series, might specify which  anything is "possible" - if you have a tape measure you might find the widths don't match well Bill | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | you are right,ishould have been more specife.my 55 is asecond series.soon as get the engine out of the pickupiwill do some measureing. thanks | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | you are right,I should have been more specific. My '55 is a second series. Soon as get the engine out of the pickup I will do some measuring. thanks Lots of good information can be found here: 55-59 Chevy Pickup Suspension - What Works?Hope that helps. Keep us in the loop as things progress.  John | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Might be worth checking with Hotrod Lincoln. I believe he is doing that very swap on a '55-'59 Panel (I don't recall the exact year), only he is using a 3/4 ton crossmember from a later truck. The basic crossmember is the same, main difference is the load rating and the one he is using has disk brakes.
Bill Burmeister | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | HOTROD LINCOLN would you have anything add? | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | after getting the eng. out of the pickup,i did some measureing.what I found,is the 55 panel frame is 3 inchs wider than the 66 pickup.i,m not sure I want to get envolve that much.so its back to the think tank. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | A Camaro/firebird subframe is way easier. That's what is on my 55 2nd series from a 79 Trans Am. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | | | |
