6 members (1955 1 Series, walter74, artinva, Wally / Montana, SNOYL, Hotrod Lincoln), 59 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#104626 06/14/2002 4:11 AM
It's gettin' hot down here and my '46, 1/2 ton doesn't have airconditioning! The previous owner sealed the windshield shut with caulk or some kind of silicone. I see in some catalogs that I can get a crank assembly rebuilt if I send in a core with a good "tongue". Does anybody out there have a good outfit that I can use or send in as a core? What should I look out for when puttin' on new winshield rubber and the crank assembly? Thanks, Jacques
Union, Justice and Confidence
#104627 06/15/2002 3:38 AM
Make sure the edge of the windshield frame doesn't have rust buildup in the channel where the rubber goes. There are 2 drain holes, one on each side of the cab corners, bottom of the windshield inner side, that should be opened. I didn't open mine because of not knowing about them, but haven't had any leak problems somehow. Good luck on finding a crank assembly. If you get one installed, don't try to crank it open at speeds above 20mph. I did that and now have to help push the window out because of bad gear teeth. It will close at any speed though,lol.
#104628 06/15/2002 10:04 PM
The hinges at the top of the windshield usually sieze up from not cranking it out for a long time. Make sure the windshield swings in and out easily, don't force and bend the metal.A tip from Tony the hack, if the truck is a driver, a select piece of wood will hold open the glass just fine. A tapered piece allows fine adjustment.use a piece of wire and a ffew screws to bind the wire around, to tie the window closed.
#104629 06/16/2002 5:28 PM
Thanks for the info, guys. What's the tongue that they refer to in the catalog? Is it part of the crank out assemblly?
#104630 06/16/2002 10:06 PM
The tongue is a strip of stainless about 1 1/2" X 6" that has a row of square holes down the center of it ,, it attaches directly to the w/screen frame and is driven by the gear ( the soft diecast bit that wears / brakes ) when you crank the wind out handle.
#104631 06/16/2002 11:07 PM
I got one from jim carter.It seems to be a good replacement.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
