1 members (classicchevs),
101
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | I had to cut the wires to my taillights when replacing the back sill on my 54. when reconnecting them I let a wire touch some metal and it sparked and now blinkers don't work - as if no power is getting to them. Brake lights & tail lights work. I checked fuses, changed the blinker unit but nothing works. Could I have fried the signal switch? I'm out of ideas and need any ideas that are out there. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, possible you fried the switch - you should be able to check it's function with an ohmmeter or voltmeter ... and in the future, always disconnect the battery when doing any wiring work, or keep one hand in your pocket  Bill | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Oh crap, so I may need a whole new turn signal unit? Yeah, I'll check it with ohmmeter but I can't believe that little current would ruin that unit. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the switch itself in a turn signal unit is replaceable and depending on just what you have, can probably be obtained from most vendors
Bill | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | So if I disconnect the flasher from the signal switch (after market 7 wire clamp-on) and clamp ohmmeter to the switch power terminal & ground, if I get a reading when engaging L or R signal lever I should get a reading if switch is good right? If I get nothing then the switch is bad. BTW, I have a mechanical 3 prong flasher in now, does it matter to replace it with an electronic flasher or are those just designed for LED lights? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Is this an add on blinker system? If so, maybe it is fed from an inline fuse. | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | It is and the fuse is good. I replaced the flasher with no success. Brake lights, tail lights work, just not the signal switch. I guess I need another one. Very weird. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't think the electronic flashers are dependable on those units .... yes, use an ohmmeter to check just what happens, you should be able to open the case up and check the switch directly, might have fried a contact in the switch or just heated a wire off it that could be fixed ... dead shorts, even if it's only for a second, can easily blow things .... if both brake lights work when the turn lever is in either off, L or R, something in the switch has to be gone if you have it wired right
Bill | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Went back to a mechanical flasher but no difference. I get nothing from ohmmeter at the flasher or switch. Took the switch apart but couldn't see anything fried. Just ordered another switch. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I guess I would be looking to see if you have power to the switch after the fuse. Some of the fuse holder contacts fail inside. I repaired one on the road last year. In order for your brake lights to work, certain parts of the switch have to work. | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | I guess that's possible, I only checked the power after the fuse holder. If so, what is the fix? | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | I guess that's possible, I only checked the power after the fuse holder. If so, what is the fix? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have power after the fuse then that isn't the problem. However, I would be checking for power right at the blinker.
The one I worked on had one of the contacts recede into the white plastic housing. I took some foil and pushed it in so the contact was made again.
