7 members (55shaker, KEVINSKI, TUTS 59, Otto Skorzeny, Lostbuthaulinass, 32Fordpuchoptop, moparguy),
107
Mod | | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | I scraped and sanded the oil pan but there is still small pockets of rust still on it. Is there anything on the open market I can use to remove the rust before painting??? 1-262-392-2989 or [email protected] Marv. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ospho or other rust converter should be available at any auto parts store
Bill | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Evaporust it is a safe non toxic rust remover. You should be able to find it online but let me know if you have any issues and I can help you out.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Some Naval Jelly and a piece of steel wool will probably remove it.
John | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | The outside of the pan? Sandblast it and paint. Your primer will thank you for all that texture.
Inside of the pan? Sandblast and clean with soap water. Coat with oil immediately to prevent rust.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have good access, a 3M rust/paint stripper wheel will get you about 90% there. Evapo-rust would be how I would complete the job. | | |
