| | | Forums66 Topics128,089 Posts1,056,355 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1 New Guy | | New Guy Joined: Jul 2014 Posts: 1 | Installed new fuel guage,new wire harness, new sending unit. Turn on ign. and wire from switch to gauge got hot and melted the insulation. Any ideas? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | need to get out the ohmeter and start checking, sounds like a dead short somewhere, maybe you have the wires reversed on the gauge - and that would probably have killed the new gauge
Bill | | | | | Joined: Aug 2014 Posts: 3 New Guy | | New Guy Joined: Aug 2014 Posts: 3 | So then which side of the gauge is the hot wire to go to? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Crafty1,
This might depend on the year/gauge.
Many original gauges have a red warning tag around the sender post (I think) - warning not to attach the power source to that lead.
I think that Advance Design trucks (47-55) gauges have the sender-lead behind the "Empty" side of the gauge?
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | There should be a wiring diagram on this site. Find out for sure which post the "Hot" wire goes. Then even if the other wire is dead grounded it should not hurt the gage. If then the power wire gets hot, then you have a short in the gauge or a ground to the hot post of the gauge. I think my 57 goes to FULL when the sending wire is dead grounded. It has a spade plug to the gage, so I cannot explain which post is the hot post, but I think it is the one behind "empty" as mentioned above.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Aug 2014 Posts: 3 New Guy | | New Guy Joined: Aug 2014 Posts: 3 | Yeah, I have that little red scrap of paper there and only the black arrow and hot can me made out. So naturally I connected the hot wire there. Another blown gauge. I could not be more frustrated with this. This should not be frickin rocket science. This is the third blown gauge. I should have just replaced all this ancient crap with Dolphin gauges and called it good. I would have had less money in it. I cant believe with all the good info and knowledge on this site I cant get the answers needed to wire one little Chinese crap gauge. SOrry. Just blowing steam.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What answers were not able to get ?
| | | | | Joined: Aug 2014 Posts: 3 New Guy | | New Guy Joined: Aug 2014 Posts: 3 | Hi Tim, Cant seem to get a straight answer on which post is hot. I suspect now that there is a short in the wire from the tank to the gauge causing a problem. I will pull the bed wood tonight to access the tank (48) Still not sure exactly which post to put the wire on a 12 volt gauge. Some say E side some say F side. I will work out the sending unit issue and then try again. Classic parts are out of gauges for now. Guess I cleaned them out! LOL The truck had ugly autometer gauges when I got it and I would like to put it back to a more classic look. Have had really bad luck with the old style gauges and speedo. This is the last attempt. after this I pop for Dolphin gauges. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks for such a good clear picture Gus. I better run out and double check mine. Steve | | | | | Joined: Apr 2011 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 22 | I have two after market 12 volt fuel gauges. They are both stamped on the back. Sending unit on the full side. 12 volt power on the empty side. Like DADS50 shows. Of course I read this after I took someones advice and hooked them up backwards and fried both. I ordered the third one yesterday.
When setting goals in life. Always aim low to avoid disappointment
| | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | i wired mine up the wrong way but it didnt fry my gauge so its not always a given. | | |
