Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (kades51, DaveV), 151 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#104578 07/28/2004 4:53 AM
On my 55 1st, the rear hood support isn't affixed to the sheetmetal so you can lift it off the bracket. Should this be stuck to the support with epoxy or some other adhesive as I have seen in other applications. There doesn't appear to be signs there was any "stick-um" on it before plus I don't know if the cowl seal would lift the sheetmetal off the support when the hood was closed. I remember seeing a fiber cushion material attached with a black tar as a metal to metal separator on hoods on some rigs.
#104579 09/04/2004 5:24 AM
Junior Member
Junior Member
I was wondering the same thing. I am starting to work on my hood on '50 and the sheet metal does not touch the brace and there is nothing between them. On my '51, there are some foam rubber-type pads between the brace and hood. Someone on here should know what should go in there.
