0 members (),
85
0
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | My 69 GMC came with 215/85/16 tires. I'd like to keep the rims but go with a wider tire, and maybe a little taller. What is a reasonable size to not cause issues? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What size truck; 1/2, 3/4 or 1 ton? 2wd? 4x4? This will all come into play.
Bill Burmeister | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 265/75/16s will clear fine in the fenders, and are roughly 32" tall and about 10.5" wide. The only limiting dimension would the wheel width, you would want around an 8-8.5" wheel for that big of a tire.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I just put a set of 235/85/16 tires on a set of those rims for my 53. The rims should handle 245 width easy enough.
EDIT: But... do you have manual or power steering? If it is manual you may want to stay in the narrower widths.
| | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Tried a 245/75 on a Dodge rim. Rim fit, to my surprise, and tire size worked perfect. So now I have a spare rim and know exactly what tires I'm looking for. | | |
