6 members (Samantha, dt235sd, homer52, chevyb, wilbur53, 32Fordpuchoptop), 122 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
#104566 03/24/2005 2:30 AM
I
Junior Member
Junior Member
I Offline
I want to paint my 63 the original chevy red with white top. Is there a paint number for the red color so I can have it blended or does someone make the chevy red color? Dupont?
Thanks, Ivor
63 chevy short/fleet 292/4speed
under construction
#104567 03/24/2005 2:47 AM
im going to use a 97 chevy truck color orange red by martin senior paints its veryy close ill get the code if you need it lmk
#104568 03/24/2005 3:15 AM
I
Junior Member
Junior Member
I Offline
Thanks, The code would help. Is there some where online I could see the color?
Thanks, Ivor
under construction
#104569 03/24/2005 5:51 AM
pick yer year and make here to see some chips - codes will be theirs tho, not general - you prolly want cardinal red
#104570 03/24/2005 6:37 AM
Ivor, My '40 was originally Swift Red and I matched that chip up with a 1997 Chevy truck Wildfire Red. Code 297C. This is a Nason (Dupont) paint code. Two Stage.
Check it out!
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
#104571 03/29/2005 2:57 AM
I used International Red. I don't know if it is right or not but it is close enough for me.
