| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 21 Junior Member | | Junior Member Joined: Nov 2004 Posts: 21 | I want to paint my 63 the original chevy red with white top. Is there a paint number for the red color so I can have it blended or does someone make the chevy red color? Dupont?
Thanks, Ivor
63 chevy short/fleet 292/4speed under construction
| | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | im going to use a 97 chevy truck color orange red by martin senior paints its veryy close ill get the code if you need it lmk | | | | | Joined: Nov 2004 Posts: 21 Junior Member | | Junior Member Joined: Nov 2004 Posts: 21 | Thanks, The code would help. Is there some where online I could see the color?
Thanks, Ivor
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pick yer year and make here to see some chips - codes will be theirs tho, not general - you prolly want cardinal red Bill | | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Ivor, My '40 was originally Swift Red and I matched that chip up with a 1997 Chevy truck Wildfire Red. Code 297C. This is a Nason (Dupont) paint code. Two Stage. Check it out! | | | | | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | I used International Red. I don't know if it is right or not but it is close enough for me. | | |
