3 members (F100Ranger, Bill Hanlon, latroca52), 147 guests, and 2 robots.
Topics128,192
Posts1,057,350
Members48,469
#104556 01/07/2005 12:25 AM
I'm preping my truck for paint and decided to start with the bed first. I took the fenders off no problem and I'm now working on the bed sides.
The bolts are rusted of course and the carriage head portion just spins in the hole when I try to turn off the nut from underneath. I'm looking for any tips that anyboby has to offer. Should I lift the bed off the frame 1st? and what's the best approach to the carriage bolts.
Any help would be appreciated.
#104557 01/07/2005 1:04 AM
If you have a cut off wheel there are a couple options: 1) try to cut a slot in the carriage bolt that fits a large flathead screwdriver, 2) use cutoff to cut bolts from the bottom. 3) third option firewrench. #1 above is suspect if bolts are really rusty. Bed on or off is personal preference and amount of room you have.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#104558 01/07/2005 3:00 AM
Tack weld the heads down and remove or break the nuts off. Then use a die grinder or cut off wheel and cut off the welds. Sometimes the heat of welding breaks loose the rust,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#104559 01/07/2005 3:43 AM
Thanks for the ideas. I had considered the gas wrench, but figured I might catch the wood on fire or some of the old undercoat that was sprayed everywhere on this truck - except for the places where it might have really helped wink
I like the slotting approach, I think I'll try that 1st.
#104560 01/07/2005 9:42 PM
I had the same problem removing the bed from my 50 longbed. I just used a drillbit the same diameter as the bolts and drilled out the heads. Once you drill through the head it will just spin off. I drilled a small pilot hole in the center of each head to make sure I didn't wabble off center with the large bit.
#104561 01/09/2005 10:07 AM
i just took a 4 inch grinder to mine on the fenders to takes about 5 minutes for each one
#104562 01/11/2005 2:00 AM
Junior Member
Junior Member
I did what 32fire did and just grinded them off. Didn't take too long.
rebuild not replace
#104563 01/11/2005 3:10 AM
I
I Offline
break em
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
