| | | Forums66 Topics128,131 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi guys,
i bought a new cardboard glovebox liner for my 49 1/2 ton and was wondering how its supposed top fit.
liner came with holes around the edge (no metal clips) and my truck has corespomding (smaller) holes around the dash opening.
i cant work out if the liner is just bolted straight to the metal, ie liner over metal rim or if there's supposed to be a trim strip that sandwhiches the liner down.
or is the liner supposed to tuck behind the dash lip and secure via captive nut clips?
ive searched for some pics or guidance but couldnt find any answers
confused.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | The liner goes around the exterior of the perimeter metal lip of the opening. The liner should have sheet metal "nuts" crimped to the cardboard to accept sheetmetal screws.
If yours does not have the "nuts", you could try speed nut clips, but you risk scratching the paint on the metal lip as the liner is a tight fit to begin with.
Maybe trying buying the liner from an different vendor. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | the vendors don't show the clips for the 49
didn't realize they were diffrent | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | thanks guys - fantastic help as always!
my truck was made january 1949.
i dont have that metal trim piece....hmmm where on earth can i find one of those!
guess i could try and make one or go the clip route....hmm
i just replaced the hinges the new ones and old look to be the same.
this truck is like no other restoration ive done - with all the re manufactured parts available and the huge volume of knowledge here
thanks again
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Interesting, never saw that trim piece. Hey Brad, what happened to Flicker??? Used to be able to down load the pictures, which I did many of for my reference file, but now there isn't any option to download the image. Did you lock out that feature?? DG
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Denny I will go in and look if I changed something it was by accident? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Denny Click the 3 dots on the bottom of the image
Then click View all sizes Then it will give you an option to download | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Been tryin' to log in to the forum for a couple of hours but after a couple of dozen try's I finally gave up. Seems to have me logged in now. Was just fine for a couple of weeks, now for the last couple of days the Stovebolt site keeps throwing me out. Anyway, maybe I can get this in before I get thrown out again.
That's why I was asking Gus, there are no three stars like there was in the past. Just the picture a few arrows at the bottom and the heading. None of the stuff that used to be on the right side of the picture.
DG
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | sorry Denny
I was looking at my ipad when I give that response. ipad still gives the 3 dots at the bottom.
on my a PC I see a arrow down symbol at the bottom of the image page. I'm able to click on that and it give's me a choice to view all sizes and down load. | | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | I have several of the thin metal surround pieces if anyone needs one | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, that does the truck Gus, thanks, that's different from the way it's been in the past so it had me going there. DG
| | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | I have a 1948 Chevrolet 3100 truck and I replaced the glove box liner as well. Mine has the metal edge trim that goes around the box. Good luck trying to find a new one. I have the original one but it is pretty bent up. I searched all over trying to find a replacement with no luck. I straightened out the original as best I could and reused it. I also ordered new screws as well and the ones I received were to big. It seems they were actually for the later 49 and up models. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | clhaney,
Send oldblue48 a PM. He has several of these glove box bands in excellent condition. I just got one. Cleaned it up and repainted it to match the dash, Looks just like new.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
