| | | Forums66 Topics128,192 Posts1,057,234 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Has anyone recommendations for a good repair and maintenance manual for all years of the 250 CID engine. Ive looked at Chilton and Haynes car and truck manuals but they are mostly about V8s and pollution control.
Stan T | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You might check Amazon, they have some books on rebuilding the Chevy 6 (194, 230, 250 and 292) engines.
John | | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Thanks joe. Great looking truck you have. I see you have the same engine and transmission in it as my 53 1/2 ton. My problem is a PO put in an alternator and power steering pump that doesn't line up with the crank pulley. The engine is a 75 but am told my dead water pump is out of a 78 and have no idea what the rest of the components are. I shall muddle through.
Stan T | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I put a power steering on my 230 in my Nova that came from a v-8. The pulley didn't line up. Took the pulley off and turned it around and it lined up then.
John | | |
