3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#104508 05/02/2003 1:57 AM
Junior Member
Junior Member
Anyone know a source for a tonneau cover for a 1950 3100?
#104509 05/02/2003 2:52 AM
Here's a neat one that the wife won't let me buy. I figured it would work by putting some 1"x1" posts on it and sit them in the stake pockets. She thinks it's gaudy, but it's definately just for the cruise nights....
Remember this movie?
MbOutdoors (Lorne)
1952 Chev 1300
#104510 05/02/2003 5:27 AM
There's a place named gaylords in Long Beach, CA that makes them for '47 & up chevy's...I haven't checked them out but I heard that they have them...
Gaylords
#104511 05/02/2003 12:57 PM
Another one that I have looked at is CheckMate.
CheckMate
Mike Kelley
1966 Chevy C10 SWB - 250 L6/S10 T5
2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
#104512 05/03/2003 12:14 AM
Junior Member
Junior Member
Thanks guys, Checker looks promising.... cool
#104513 05/04/2003 8:45 PM
Was going to wait awhile to post the question but this may be the time to bring it up.
Does anyone have any ideas on how a soft tonneau cover could be utilized on a Task Force era shortbed? Clincher is I would not want to drill holes for snaps and not crazy about gluing down Velcro strips. Too much money and time invested in bodywork and paint to start destroying the efforts. Only idea I seem to be able to come up with is utilizing the stake pockets in some way. Any sources would be appreciated.
Bruce
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#104514 05/05/2003 7:47 AM
Possibly some sort of frame sections that run across the bed between the stake pockets? However, it seems like you would still need snaps at the front and the tailgate or it would blow off, unless you made a frame that hooked in the stake pockets and ran all the way around the bed...
1954 GMC De Luxe COE
#104515 05/05/2003 8:35 AM
Bruce, I once had to come up with a soft tonneau for a client with your same concerns about permanent attachments. What we ended up with was six tension points at the stake pockets by using flush-cut wood stakes and hairpin-style hood locks. I installed stainless "eyes" in the vinyl cover to slip over the pins under slight tension. In order to keep the edges from flapping and stripping the paint, I sewed magnets into the perimeter at 4" intervals. It looks like a fat, slightly boxy welt strip, but I wanted to make sure the magnet was strong enough to hold on with a layer of vinyl between it and the steel. It actally seems to hold better than snaps, although the truck it's on doesn't go past 60 mph so we don't know what speed will pull the magnets loose.
edit: I remember him telling me he once forgot to set the hairpins on the rear corners. He didn't make that mistake twice, as the cover flapped once and, uh, nearly ruined his seatcovers. eek If I were to try this again, I think I would have more magnets (closer together) on the front and rear edges, for such "senior moments."
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#104516 05/05/2003 1:01 PM
Bruce-when I had my S-10, I had a wonderful soft tonneau made by a company in Michigan called Extang. It had "no drill" aluminum frame rails which attached (with clamps) to the rails of my box. The cover then stretched over the frame. Try your local truck and van supply place and see if they have a "rail tonneau cover" for '73-'87 GM stepside. Pretty sure the newer truck stepside box was almost identical to the '54-up box. Hope this helps.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#104517 05/05/2003 3:33 PM
GMCpanel, something like your suggestion is what I have had going thru the noggin.
Hedgehog, This sounds like an interesting approach and I will definitely file this idea at the top of the list. Look for an email from me.
Wannabe, I have seen these clamp on aluminum frame covers however I have as yet to figure out how the clamps could be clamped to the smooth sidewalls on the inside of the bed.
Thanks all,
Bruce
Bruce
#104518 05/05/2003 3:45 PM
Bruce-those rail covers actually have an internal expanding clamp to attach them down in the stake pockets on the stepside type truck. On my S-10, they simply clamped on the inside of the top bed rail.
They (Extang) call them the "No Damage To Truck" tonneau-and they ain't kidding! The price isn't too bad, either. Dunno if they've got a website or not, might be worth a Google.
Regards,
Wannabe smile
#104519 05/05/2003 4:40 PM
Thanks Wannabe I will give it a try and try to locate them.
Bruce
Bruce
#104520 05/05/2003 7:28 PM
Wannabe, Just emailed Extang for info. FYI here is the link to their site.
http://www.extang.com/talkindex.html
Bruce
Bruce
#104521 05/06/2003 5:08 PM
Thank you for contacting Extang. Unfortunately we don’t have any systems that will fit your truck. We do not make systems that go back that far. I apologize for any inconvenience this may have caused you. If you have any further questions, please don’t hesitate to ask.
Thanks again.
frown :mad: :confused:
Bruce
#104522 05/06/2003 8:11 PM
I just looked at the year of your truck again - you have those stupid slanted bed top rails. That will make installing any tonneau cover an interesting challenge.
#104523 05/06/2003 11:46 PM
I have a design for one floating around in my head that I am going to try after I finish the rest of the truck. It would be fiberglass with an aluminum frame. It would fit the bed sides like a keystone and have sloped rubber gaskets with rain gutters to drain the water off and use the stake pockets to secure it. I have a few years before I do it though.
Paint & Body Shop moderator
#104524 05/13/2003 5:37 AM
"MONGO"
"MONGO"
Read this post last week and I was sure I had pictures of the bed cover one of the guys in our club built for his '47 but couldn't find them, Luckily he came to our cruise night last saturday and I was able to get some pictures of it. Hope these help, It has a steel tubing frame and it has some thin metal on top of it. and the whole thing has padding and some vinal (sp) covering it all. Also he has it hinged at the front of the bed,
Gas shocks on the sides, and some rubber tubing for a gasket all the way around the bottom of the cover.
MONGO
[img]http://www.chevygmcofkc.org/Gallery/data/504/1DCP_1735s.jpg[/img]
[img]http://www.chevygmcofkc.org/Gallery/data/504/1DCP_1733s.jpg[/img]
[img]http://www.chevygmcofkc.org/Gallery/data/504/1DCP_1731s.jpg[/img]
[img]http://www.chevygmcofkc.org/Gallery/data/504/1DCP_1729s.jpg[/img]
[img]http://www.chevygmcofkc.org/Gallery/data/504/1DCP_1730s.jpg[/img]
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#104525 05/13/2003 6:12 AM
KC, that's sure a slick (and HOMEBUILT, yet), solution for the early truck tonneau. Sharp lookin' truck, too. Thanks for sharing your pix.
Regards,
Wannabe smile
#104526 05/20/2003 11:39 AM
Mike K - thanks for the tip on Checker Pro, http://www.checkerpro.com/ I've been looking for a hard tonneau and gots lots of runaround from Gaylords - they didn't really seem interested in selling their $1000 covers. Checker was prompt, friendly, and a LOT cheaper. They're in the neighborhood (6 hours) so I dropped in to have it installed for free. I'm really pleased with cover. See it at
http://chuckthetruck.homestead.com/Page21.html
Thanks again Mike and Thanks Stovebolt!
#104527 05/20/2003 12:51 PM
chuckthetruck - Glad to be of service. The installation looks sweet.
Mike Kelley
#104528 05/20/2003 7:37 PM
"MONGO"
"MONGO"
Chuck, Looks really sweet, I like it even better than other's I've seen. I wanna run Side boards in my stake pockets eventually and like the way it leaves the pockets open. I wonder if I built my side boards right if they would clear it?
MONGO
Mongo's Garage
#104529 05/21/2003 12:09 PM
KC, they build them custom so I'm sure you could coordinate with them.
