2 members (DennisM, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 40 Junior Member | | Junior Member Joined: Dec 2002 Posts: 40 | Anyone know a source for a tonneau cover for a 1950 3100? | | | | | Joined: May 2002 Posts: 32 Member | | Member Joined: May 2002 Posts: 32 | Here's a neat one that the wife won't let me buy. I figured it would work by putting some 1"x1" posts on it and sit them in the stake pockets. She thinks it's gaudy, but it's definately just for the cruise nights.... Remember this movie?
MbOutdoors (Lorne) 1952 Chev 1300
| | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | There's a place named gaylords in Long Beach, CA that makes them for '47 & up chevy's...I haven't checked them out but I heard that they have them... Gaylords | | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | Another one that I have looked at is CheckMate. CheckMate
Mike Kelley 1966 Chevy C10 SWB - 250 L6/S10 T5 2002 Chevy Ext 1500 4x4
Http://myol66.wordpress.com
| | | | | Joined: Dec 2002 Posts: 40 Junior Member | | Junior Member Joined: Dec 2002 Posts: 40 | Thanks guys, Checker looks promising....  | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Was going to wait awhile to post the question but this may be the time to bring it up. Does anyone have any ideas on how a soft tonneau cover could be utilized on a Task Force era shortbed? Clincher is I would not want to drill holes for snaps and not crazy about gluing down Velcro strips. Too much money and time invested in bodywork and paint to start destroying the efforts. Only idea I seem to be able to come up with is utilizing the stake pockets in some way. Any sources would be appreciated. Bruce
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Possibly some sort of frame sections that run across the bed between the stake pockets? However, it seems like you would still need snaps at the front and the tailgate or it would blow off, unless you made a frame that hooked in the stake pockets and ran all the way around the bed... | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Bruce, I once had to come up with a soft tonneau for a client with your same concerns about permanent attachments. What we ended up with was six tension points at the stake pockets by using flush-cut wood stakes and hairpin-style hood locks. I installed stainless "eyes" in the vinyl cover to slip over the pins under slight tension. In order to keep the edges from flapping and stripping the paint, I sewed magnets into the perimeter at 4" intervals. It looks like a fat, slightly boxy welt strip, but I wanted to make sure the magnet was strong enough to hold on with a layer of vinyl between it and the steel. It actally seems to hold better than snaps, although the truck it's on doesn't go past 60 mph so we don't know what speed will pull the magnets loose. edit: I remember him telling me he once forgot to set the hairpins on the rear corners. He didn't make that mistake twice, as the cover flapped once and, uh, nearly ruined his seatcovers.  If I were to try this again, I think I would have more magnets (closer together) on the front and rear edges, for such "senior moments." | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Bruce-when I had my S-10, I had a wonderful soft tonneau made by a company in Michigan called Extang. It had "no drill" aluminum frame rails which attached (with clamps) to the rails of my box. The cover then stretched over the frame. Try your local truck and van supply place and see if they have a "rail tonneau cover" for '73-'87 GM stepside. Pretty sure the newer truck stepside box was almost identical to the '54-up box. Hope this helps. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | GMCpanel, something like your suggestion is what I have had going thru the noggin.
Hedgehog, This sounds like an interesting approach and I will definitely file this idea at the top of the list. Look for an email from me.
Wannabe, I have seen these clamp on aluminum frame covers however I have as yet to figure out how the clamps could be clamped to the smooth sidewalls on the inside of the bed.
Thanks all, Bruce
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Bruce-those rail covers actually have an internal expanding clamp to attach them down in the stake pockets on the stepside type truck. On my S-10, they simply clamped on the inside of the top bed rail. They (Extang) call them the "No Damage To Truck" tonneau-and they ain't kidding! The price isn't too bad, either. Dunno if they've got a website or not, might be worth a Google. Regards, Wannabe
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Thanks Wannabe I will give it a try and try to locate them. Bruce
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Wannabe, Just emailed Extang for info. FYI here is the link to their site. http://www.extang.com/talkindex.html Bruce
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Thank you for contacting Extang. Unfortunately we don’t have any systems that will fit your truck. We do not make systems that go back that far. I apologize for any inconvenience this may have caused you. If you have any further questions, please don’t hesitate to ask. Thanks again.  :mad: :confused:
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I just looked at the year of your truck again - you have those stupid slanted bed top rails. That will make installing any tonneau cover an interesting challenge. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I have a design for one floating around in my head that I am going to try after I finish the rest of the truck. It would be fiberglass with an aluminum frame. It would fit the bed sides like a keystone and have sloped rubber gaskets with rain gutters to drain the water off and use the stake pockets to secure it. I have a few years before I do it though.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | KC, that's sure a slick (and HOMEBUILT, yet), solution for the early truck tonneau. Sharp lookin' truck, too. Thanks for sharing your pix. Regards, Wannabe
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Mike K - thanks for the tip on Checker Pro, http://www.checkerpro.com/ I've been looking for a hard tonneau and gots lots of runaround from Gaylords - they didn't really seem interested in selling their $1000 covers. Checker was prompt, friendly, and a LOT cheaper. They're in the neighborhood (6 hours) so I dropped in to have it installed for free. I'm really pleased with cover. See it at http://chuckthetruck.homestead.com/Page21.html Thanks again Mike and Thanks Stovebolt! | | | | | Joined: Oct 2000 Posts: 98 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 98 | chuckthetruck - Glad to be of service. The installation looks sweet.
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Chuck, Looks really sweet, I like it even better than other's I've seen. I wanna run Side boards in my stake pockets eventually and like the way it leaves the pockets open. I wonder if I built my side boards right if they would clear it? MONGO | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | KC, they build them custom so I'm sure you could coordinate with them. | | |
