1 members (Phak1),
48
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | While I was updating the Links Page on this site, I came across an interesting Paint FAQ site -- Bob Story's Automotive Paint FAQ's I didn't look all the way through it, but I thought you all might find it helpful. BTW, the new Hobart Champ is great! Doesn't do too well on sheet metal, though... Good thing I didn't get rid of the Mighty Mite! Happy New Year John
~ One of many.
| | | | | Joined: Sep 2000 Posts: 33 Member | | Member Joined: Sep 2000 Posts: 33 | Thank ya very much for the link ... good painting info there. | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | You say the Hobart Handler (135?) doesn't work well for sheetmetal. I'm getting ready to buy a MIG unit and need to know - what's wrong with it? What feature does it NOT have that will allow one to weld sheetmetal? | | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Nice site--I enjoyed the FAQ on Brain Damage and thought it was particurly insightful :p
Buzz'n Half Dozen
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Paul, I got the Champ 2060 welder/generator, not the handler. My welder only goes down to about 40 amps (I think) and I was burning through the upper radiator shroud that GL sent me. Remember though that I am definately not much of a welder when it comes to hard stuff. For the really thin stuff, I think I'll just stick to my Mighty Mite 110v welder I got from Eastwood about 7 years ago.
From what I saw at the welding supply store, I would say the Handler is an excellent piece of gear -- but I couldn't tell you how well it does on sheet metal. If it's a mig welder (I think it is) then it should be fine. My welder is not -- it's just a stick welder.
Good luck though. Like the others have said, I don't think Hobart makes a bad product. I'm really impressed with mine.
Regards, John
~ One of many.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | John, Glad to hear your welder worked out. Now we want to see pictures of your big truck with the welding outfit on a custom welded chassis that you can lift on/off when you need to go on a repair run.  | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Another nice paint site is www.paintchip.com and it has color chips and a store and tips and..... On the welder's, you need a MIG and use the gas for sheetmetal to be good. I have used the flux-wire and it's not as clean and needs chipping just like a stick welder. I had a cheap one, hated it, and then bought a Lincoln 100. Lot's better quaility of gun and machine! sold it cause I wasn't using it and needed cash at time....DUMB! Brain fart! :rolleyes:
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
