9 members (carbking, Mike B, klhansen, Youngin' Tut 59, Pete1946, Gray_Ghost, BarryP, dt235sd, 1 invisible), 89 guests, and 3 robots.
Topics128,139
Posts1,056,758
Members48,454
Since my A.A.W. kit came with the wiring,I'm thinking about mounting a switch under the floor pan,like my friend's '66 G.M.C. was configured. I'll probably buy a shifter from a scrapyard,with the tab already on it,rather than try and weld one up. If I'm lucky,I'll be able to find a good switch as well. Whatcha think?
Mo' Tater
shouldn't be hard to do the factory backup light switch setup
Wow,Bill ! That's the set-up! I didn't even know that was an available accessory in'55. Back-up's a bolt-on tab,on the shifter. Thought it was welded. I learned how to drive,in my friend's '66 G.M.C.,but that was back in'69,so don't remember how the unit was attached,except for the button on the trans pan. THANKS!!
Mo' Tater
