8 members (68ironhead, Nhluvstruck, 55shaker, MickeyP, elhippie64, treegrower, David Bush, 1 invisible),
46
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 33 | I am building a Custom Hot Rod 1962 Chevy Panel Delivery Truck an i want to upgrade the Front brakes to disc an a new power brake master cylinder set up i'm looking for idea's to do the disc brake part with out having to spend hundred's of dollars what are some idea's i could do on a budget please feel free to give your idea's an opinion's
1957 Chevy Service Station Wrecker
| | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Here's a start: http://www.persh.org/Pickup/FrontSuspension.htm1962 was the last of the torsion bars, so I don't know what frame differences may exist between 62 and newer, but I doubt there are many. 63-87 crossmembers are basically the same, so it makes switching to a 73 or newer disc brake front end easy. You can also swap power brake boosters and steering fairly easily. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | You could just buy some new spindles that have mounts for disk brake calipers.
I too have been looking into changing my torsion front end. I think I'm leaving it and changing spindles. My next choice was to find a 72-75 chevy truck with disc brakes and replace the cradle and suspension, brakes, etc.. | | |
