0 members (), 66 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1044434 07/23/2014 10:24 PM
when changing my 6 volt tail lights to 6 volt LED's do I need a 6 volt LED flasher or am I ok with my stock one? Can I have LED's in the rear and no place else?? Thanks, Paul
You can have LED's in the same circuit as regular bulbs, yes. You may or may not need an LED flasher if you have regular bulbs in the same circuit. Try it first with your regular flasher, and if it doesn't work then you can get the LED flasher. It's just trial and error as it depends on your specific wiring and bulbs.
My '62 Bel Air has LED taillights but incandescent front lights, and the regular flasher works great.
My '46 has LED front and rear and needs the LED flashers for both signals and 4-ways.
My 46 GMC on Photobucket
46gmcpu #1044459 07/24/2014 12:19 AM
Thanks, I wasn't sure....Paul
I
I Offline
The flasher I had before my LED conversion wouldn't work if the tail lights were LEDS but the parking light turned signal were filiment bulbs. Didn't bother me much because a full LED conversion was the plan from the get go.
My 57 370 has bulbs on the fenders and LED's on the rear and they both work fine with the original flasher.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Thanks, that's what I wanted to here....Paul yahoo
