| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | when changing my 6 volt tail lights to 6 volt LED's do I need a 6 volt LED flasher or am I ok with my stock one? Can I have LED's in the rear and no place else?? Thanks, Paul | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | You can have LED's in the same circuit as regular bulbs, yes. You may or may not need an LED flasher if you have regular bulbs in the same circuit. Try it first with your regular flasher, and if it doesn't work then you can get the LED flasher. It's just trial and error as it depends on your specific wiring and bulbs.
My '62 Bel Air has LED taillights but incandescent front lights, and the regular flasher works great.
My '46 has LED front and rear and needs the LED flashers for both signals and 4-ways. | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Thanks, I wasn't sure....Paul | | | | | Joined: Jan 2014 Posts: 18 New Guy | | New Guy Joined: Jan 2014 Posts: 18 | The flasher I had before my LED conversion wouldn't work if the tail lights were LEDS but the parking light turned signal were filiment bulbs. Didn't bother me much because a full LED conversion was the plan from the get go. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | My 57 370 has bulbs on the fenders and LED's on the rear and they both work fine with the original flasher.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Thanks, that's what I wanted to here....Paul  | | |
