7 members (SmalltownTRKGuy, 52Carl, Ponchogl, GradyB, Otto Skorzeny, GRNHydra, 1 invisible),
76
0
Mod | | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | I've been trying to straighten out the best valve cover I have. Of the 2 covers I own heating and lightly trying to get it real straight is not quite what I like.My question is can I apply some body filler to the cover or will the heat off the engine disagree?  | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | You might try looking in the swap meet here on the Stovebolt page.I am sure someone will contact you or know someone who will most likely know where to find a good straight valve-cover.
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | I did it some Pontiac valve covers. I used four '65 - '66 valve covers to make two. I cut the flange off of two and the top off of two then welded them back together. This made two tall old style valve covers that would fit the late model engines. I used lots of Bondo due to welding with a gas welded. With my new mig, I could of got away with a lot less. I never had a problem with it. Joe | | | | | Joined: May 2001 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 71 | Eastwood sells a body filler called Metal 2 Metal that's supposed to withstand high heat applications. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | I've used JB Weld on oil pans ,etc. with good results. Mix it up and spread it like Bondo.Then sand and or file it smooth. | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | I sure wan't to thank all of you, for your time and help.This here forum is the only way to go for help on any of your questions, problems etc. etc.. Look to start the engine the 1st of Jan. and hopefully my body filler stays together.Thanks again..  | | |
