8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible), 57 guests, and 4 robots.
Topics128,075
Posts1,055,919
Members48,429
#104458 11/30/2002 4:55 AM
I've been trying to straighten out the best valve cover I have. Of the 2 covers I own heating and lightly trying to get it real straight is not quite what I like.My question is can I apply some body filler to the cover or will the heat off the engine disagree? frown
#104459 11/30/2002 10:27 AM
You might try looking in the swap meet here on the Stovebolt page.I am sure someone will contact you or know someone who will most likely know where to find a good straight valve-cover. cool
#104460 12/01/2002 10:49 PM
I did it some Pontiac valve covers. I used four '65 - '66 valve covers to make two. I cut the flange off of two and the top off of two then welded them back together. This made two tall old style valve covers that would fit the late model engines. I used lots of Bondo due to welding with a gas welded. With my new mig, I could of got away with a lot less. I never had a problem with it. Joe
#104461 12/02/2002 10:29 PM
Eastwood sells a body filler called Metal 2 Metal that's supposed to withstand high heat applications.
#104462 12/03/2002 2:36 PM
I've used JB Weld on oil pans ,etc. with good results. Mix it up and spread it like Bondo.Then sand and or file it smooth.
#104463 12/09/2002 4:41 AM
I sure wan't to thank all of you, for your time and help.This here forum is the only way to go for help on any of your questions, problems etc. etc.. Look to start the engine the 1st of Jan. and hopefully my body filler stays together.Thanks again.. smile
