6 members (bucktruck, dt235sd, Stelonlevo, Hotrod Lincoln, Mike B, 1 invisible), 104 guests, and 2 robots.
Topics128,119
Posts1,056,648
Members48,450
I'd like to add a set of auxiliary leaf springs to the rear of my 1959 1-ton. My 38-63 master parts book lists the same part number for auxiliary springs for 55-62 1-tons. Are there any other auxiliary/helper leaf springs that would fit? (without much modification)
Also, would anyone be able to email or post pictures of a 1-ton with the second set of rear springs? I'm curious how they mount, if they need another set of spring mounting brackets.
Thanks for the help.
1959 Chevrolet 3800 Pickup
1937 Chevrolet GC Panel
Can you still call it a barn find if it's your barn?
your best bet for helper springs would be to consult with a local spring shop, there are a number of possibilities that would be much more readily available than any originals
•1952 Chevrolet 3800 pickup
---All pictures---
I think what Grigg installed is so much better than the old helper springs that you may want to consider that approach. You have so much under your control and those bags can be inflated when you want.
1951 1 Ton Completed
And they're not expensive either.
---All pictures---
Thanks for the help. I'm going to keep looking for leaf springs. But for the air springs, what brands are out there?
Several, Firestone has an good reputation and covers a lot of models.
Probably going to look for a kit that has lower brackets that fit your axle tube diameter and then make your own upper brackets.
Mine came from a later P30 chassis motor home, happens to have 4" round axle tubes like the 1.5 and 2 ton AD trucks.
---All pictures---
Moderated by  Dusty53
