| | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | I'd like to add a set of auxiliary leaf springs to the rear of my 1959 1-ton. My 38-63 master parts book lists the same part number for auxiliary springs for 55-62 1-tons. Are there any other auxiliary/helper leaf springs that would fit? (without much modification)
Also, would anyone be able to email or post pictures of a 1-ton with the second set of rear springs? I'm curious how they mount, if they need another set of spring mounting brackets.
Thanks for the help.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | your best bet for helper springs would be to consult with a local spring shop, there are a number of possibilities that would be much more readily available than any originals
Bill | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think what Grigg installed is so much better than the old helper springs that you may want to consider that approach. You have so much under your control and those bags can be inflated when you want. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | And they're not expensive either. | | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Thanks for the help. I'm going to keep looking for leaf springs. But for the air springs, what brands are out there?
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Several, Firestone has an good reputation and covers a lot of models. Probably going to look for a kit that has lower brackets that fit your axle tube diameter and then make your own upper brackets.
Mine came from a later P30 chassis motor home, happens to have 4" round axle tubes like the 1.5 and 2 ton AD trucks. | | |
