2 members (Patina 54, Chris's 46 / 515), 78 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Hey guys, quick question, I have the opportunity to buy a 1958 GMC cab five window 1 ton, the question is, if I remove the pillars from the corner glass would that make it a big back window Chevy cab?
Scott
Chevytruckdaddy
You can't make it a Chevy cab without changing the dashboard.
I'd like to know about the windows also. However I think it is cooler looking with the dividers.
The only thing GMC is the cab, everything else is Chevy. So the question still stands if I remove the pilers will a Chevy big back window glass fit? I agree the three windows are cool. I'm buying this unit really cheap.
Chevytruckdaddy
If it's like this I think it would be much cooler and more desirable as a 5-window. Why make it more common when it's less common?
My 46 GMC on Photobucket
look closely, no you can't "remove the dividers and install the big window glass" - unless you can rebuild the seal mounting flange across those areas, the dividers aren't installed in a big window cab, they're part of a 3rd cab style that was GMC heavy duty trucks only
Thank you for the valuable input. I haven't seen the truck and at this point I think I'm going to pass on it.
Thank you all
Chevytruckdaddy
