9 members (Rusty Heaps, 1955 1 Series, 55shaker, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55),
157
0
Mod | | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Hey guys, quick question, I have the opportunity to buy a 1958 GMC cab five window 1 ton, the question is, if I remove the pillars from the corner glass would that make it a big back window Chevy cab?
Scott
Chevytruckdaddy
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You can't make it a Chevy cab without changing the dashboard.
I'd like to know about the windows also. However I think it is cooler looking with the dividers. | | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | The only thing GMC is the cab, everything else is Chevy. So the question still stands if I remove the pilers will a Chevy big back window glass fit? I agree the three windows are cool. I'm buying this unit really cheap.
Chevytruckdaddy
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If it's like this I think it would be much cooler and more desirable as a 5-window. Why make it more common when it's less common? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | look closely, no you can't "remove the dividers and install the big window glass" - unless you can rebuild the seal mounting flange across those areas, the dividers aren't installed in a big window cab, they're part of a 3rd cab style that was GMC heavy duty trucks only Bill | | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Thank you for the valuable input. I haven't seen the truck and at this point I think I'm going to pass on it.
Thank you all
Chevytruckdaddy
