1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | On my 50 chev 3100 I have the drivers door glass out and want to change the glass run channel. but the the lower channel at rear of door is too narrow to accomodate the new glass run which seems to be the same as what came out .. when i removed the run a while ago I did not notice if the run went all the way down into the lower removable run, I just assumed it did, could that removable run been changed at some point , it does have weld spot on it .. maybe I can spread it enough to get the run in..It acually looks like it had its own built in run because the edges of it have a stainless bead on the edge and remnants of felt . any Ideas would help ....thanks Fred | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't know about the '50 but my '38 car has an upper and lower channel. Hopefully someone has dealt with the same issue you're having and will be able to provide more information. Good luck with it.
| | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | Thanks Tiny and Brad.. Brad those photos were most helpful .. It looks like someone has used a differant piece of channel and welded the bracket on the bottom .. At least this way I know what Im dealing with .. thanks again for the prompt responses.. Fred | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The door hinge side is spot welded ...pic... The door latch side is removable ...pic... ...pic... The replacement guides are just a bit short, at least that's what I found. | | |
