1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Was wondering if anyone has used the 47-48 under bed tank in a 40. Seems like it would work to me but I've never seen the 48-48 setup in person. This setup comes with all the brackets. http://www.oldchevytrucks.com/cart/product.asp?prodid=MEG159&i=|||||
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | It won't fit. It's too wide for a 40. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Boogers. It would be too easy anyway. Thanks for the answer InMy40s.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | BTW, if you use anything old make sure you have it boiled out. I ruined an engine running bad gas through it. If your gas comes out of the tank anything other than clear don't use it! | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Ouch! I'll be sure to do that if I go used, but I am probably looking at new custom.
Dennis
40 Chevy 1/2 ton
