4 members (Gdads51, cmayna, FAST55, Gray_Ghost), 113 guests, and 0 robots.
Topics128,111
Posts1,056,258
Members48,437
Junior Member
Junior Member
Had a friend over yesterday, we worked on "THE PANEL", cutting out 4 rusted area's and welding in home-made patch panels......3 turned out great, i wished i could have found a passenger side rear fender...back patch panel...off a donor fender or store-bought panel.....any idea's where i could get one????only need about 6" slice off the rear fender on the bottom of the section near the rear bumper........had a good day popping out dents and my friend did a great job welding in the panels...(wished i could weld good)....all idea's appreciated.thanks
1950 Chevy Panel 310
I've read they are the same contour as the pickup fenders only half as wide. If so you should be able to cut what you need off one.
I've see those fenders available in fiberglass reproduction, but otherwise I think you are stuck looking for a better fender, or cutting a patch out of a pickup fender. Panels and Suburbans seem to rust pretty badly back in that area, so finding a good one could be tough.
Junior Member
Junior Member
Cletis----fender's half as wide???/please explain.........as i am a rookie at this truck repair/body work....thanks
All I know about it is what I've read-
panel fender discussion
i miss obscene phone calls...
Anonymous
Unregistered
Anonymous
Unregistered
Quote
i wished i could have found a passenger side rear fender...back patch panel...off a donor fender .....any idea's where i could get one????only need about 6" slice off the rear fender on the bottom of the section near the rear bumper...........all idea's appreciated.thanks[/QB]
M.T. can hack out a patch panel outta a fender. wink
