0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 40 Junior Member | | Junior Member Joined: May 2004 Posts: 40 | Had a friend over yesterday, we worked on "THE PANEL", cutting out 4 rusted area's and welding in home-made patch panels......3 turned out great, i wished i could have found a passenger side rear fender...back patch panel...off a donor fender or store-bought panel.....any idea's where i could get one????only need about 6" slice off the rear fender on the bottom of the section near the rear bumper........had a good day popping out dents and my friend did a great job welding in the panels...(wished i could weld good)....all idea's appreciated.thanks
1950 Chevy Panel 310
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've read they are the same contour as the pickup fenders only half as wide. If so you should be able to cut what you need off one. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've see those fenders available in fiberglass reproduction, but otherwise I think you are stuck looking for a better fender, or cutting a patch out of a pickup fender. Panels and Suburbans seem to rust pretty badly back in that area, so finding a good one could be tough.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2004 Posts: 40 Junior Member | | Junior Member Joined: May 2004 Posts: 40 | Cletis----fender's half as wide???/please explain.........as i am a rookie at this truck repair/body work....thanks
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | All I know about it is what I've read- panel fender discussion | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 |
i miss obscene phone calls...
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | i wished i could have found a passenger side rear fender...back patch panel...off a donor fender .....any idea's where i could get one????only need about 6" slice off the rear fender on the bottom of the section near the rear bumper...........all idea's appreciated.thanks[/QB] M.T. can hack out a patch panel outta a fender.  | | |
