0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | I was wondering How hard it would be to make my own wheel tubs for a 1948 GMC. Or what donor truck i could maybe take the wheel tubs out of. Thanks, Mike | | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | I made wheel tubs for my '38 by cutting out the shape on one bed side (do a nice job) and use it as a patern for the other side so they match . Then I had a metel shop cut 2 - 14 gauge strips about 8" wide .(one for each side) I welded this strip to the cut out part at 90 degree angle. there is the tub to weld to the opening of the bed side. Just be for warned to go slow welding this in because I got a slight bow in my bed side and I was going easy on the heat ! I'v gotten several positive comments on it so I guess it turned out alright . | | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Hi,Thanks for the reply. I talked to my shop teacher in school today. We were thinking if i could get a 55 gallon drum and just cut it to fit. that it would work pretty well. What do you guys think of this idea Thanks,' Mike | | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | another option is to go to your local home builders supply store and look for a half ring that fit into the ground around basement windows. A plus to this is they are Galvanized . They also have bolt holes to use to bolt them in with out welding ------------------- 37 Chevy 1/2 Ton
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
| | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I don't know what kind of look you are wanting,but I saw a 50 model at a show using around 65 chevy rear wheelwells,looked cool.  | | | | | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Thanks for the replys ill look into both of those. Mike | | |
