3 members (GMCJammer51, 66flea, Southerntruck), 84 guests, and 2 robots.
Topics128,049
Posts1,055,682
#104336 03/21/2002 3:30 AM
I was wondering How hard it would be to make my own wheel tubs for a 1948 GMC. Or what donor truck i could maybe take the wheel tubs out of.
Mike
#104337 03/23/2002 5:33 AM
I made wheel tubs for my '38 by cutting out the shape on one bed side (do a nice job) and use it as a patern for the other side so they match . Then I had a metel shop cut 2 - 14 gauge strips about 8" wide .(one for each side) I welded this strip to the cut out part at 90 degree angle. there is the tub to weld to the opening of the bed side. Just be for warned to go slow welding this in because I got a slight bow in my bed side and I was going easy on the heat ! I'v gotten several positive comments on it so I guess it turned out alright .
#104338 04/05/2002 1:23 AM
Hi,Thanks for the reply. I talked to my shop teacher in school today. We were thinking if i could get a 55 gallon drum and just cut it to fit. that it would work pretty well. What do you guys think of this idea
Thanks,'
Mike
#104339 04/07/2002 3:23 PM
another option is to go to your local home builders supply store and look for a half ring that fit into the ground around basement windows. A plus to this is they are Galvanized . They also have bolt holes to use to bolt them in with out welding
37 Chevy 1/2 Ton
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
#104340 04/07/2002 3:29 PM
I don't know what kind of look you are wanting,but I saw a 50 model at a show using around 65 chevy rear wheelwells,looked cool. grin
#104341 04/08/2002 3:37 AM
Thanks for the replys ill look into both of those.
Mike
