3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
#1043037 07/16/2014 10:58 PM
Does anyone know how much a 3100 and/or a 3200 1/2 ton Task Force pickup weighs (empty of course)? I'm looking to replace a jack for my truck.
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #1043047 07/16/2014 11:58 PM
it'll weigh at least a 1/2T less than the GVW, or about 3000# depending on how it's equipped, but unless you're thinking of a jack that will lift all 4 wheels off the ground at once, the curb weight doesn't mean anything - are you sure you'll never need to fix a flat on the road when it's loaded? do you want to get a jack that's 'just enough'? get a quality bottle jack with a 5 ton capacity and you'll be able to do most anything needed, anything less is false economy
MarkT #1043092 07/17/2014 3:32 AM
Bill - I don't plan on having all 4 wheels off the ground at once. I'm just thinking of having to change a tire on the road in an emergency. I have an older 4 ton bottle jack that I'll probably just use for my car and get something stronger for the truck like a 5 or 7 ton jack.
MarkT #1043104 07/17/2014 4:37 AM
Your gross vehicle weight for a 3104 pickup would not be more than 5000 lbs. A 2ton jack would be more than enough to change a wheel/tire.
MarkT #1043175 07/17/2014 5:13 PM
I usually lean toward the side of "more is better" when it comes to bottle jacks. it makes me feel a little more comfortable as long as it's not overkill.
MarkT #1043540 07/19/2014 3:32 PM
Had to weigh my stock 1959 short bed step side with a 235 in the DMV registration process. It was 3,580 lbs.
Bob
1959 Chevy Apache Short Bed Step Side
1967 Cadillac DeVille Convertible
1967 Pontiac Firebird Convertible
MarkT #1043623 07/20/2014 1:06 AM
3405 lb curb weight per the 1959 Chevrolet Truck Specification Data
