1 members (chemanic),
87
Mod | | | Forums66 Topics128,134 Posts1,056,416 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 11 New Guy | | New Guy Joined: Sep 2005 Posts: 11 | Is it my imagination, or is the 4 speed tranny from a 1947 Advanced Design GMC just a little different in dimensions than all other years? I pulled one off a '47 and when I went to install it on a 1950 Chevy, it is shorter and the mounting face to the bell housing is different. Now I'm wondering if my 1950 has some odd-ball housing. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 52Pickup, welcome, the 1947 four speed is a crashbox (non-synchronized) and the last year it was used. In 1947 the bodies changed but not the mechanicals, 1948 was the first year for the SM420 synchronized transmission, hope that helps. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That early 4 speed was used from 1931-47.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Patrick's has an article about engine swaps. (patricksantiquecars.com. Click on Articles.) It sounds like if you get the bell housing that was on the engine the transmission came from, it should fit on your engine and allow you to use the '47 transmission. You may have to deal with driveshaft/torque tube lengths and number of splines , though. Someone with more knowledge will probably provide info on this.FYI,I have learned from the Stovebolt site that there can be (in different components)differences between Chevy and GMC
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The late 1947 1/2 ton, the first year for the Advance Design truck, was a one year only design combo. It used the early non-synchro 4 speed and had a longer torque tube than the 1948-54 truck because of the shorter transmission.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 52 Pickup,
New Design is the GM name for 1947-1955st series GMC trucks. Advance-Design is the GM name for Chevrolet trucks for those years.
If you bought that 47 transmission, post it for sale in the Swap Meet. Someone with a 1947 model truck might need it or want it for a spare.
| | | | | Joined: Sep 2005 Posts: 11 New Guy | | New Guy Joined: Sep 2005 Posts: 11 | Thanks to everyone for the responses to my transmission question. | | |
