9 members (KEVINSKI, Sjm, tclederman, Oswald, Cosmo, Otto Skorzeny, mick53, 2 invisible),
145
Mod | | | Forums66 Topics128,260 Posts1,058,288 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Does anyone know how much a 3100 and/or a 3200 1/2 ton Task Force pickup weighs (empty of course)? I'm looking to replace a jack for my truck.
Thanks. Mark | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it'll weigh at least a 1/2T less than the GVW, or about 3000# depending on how it's equipped, but unless you're thinking of a jack that will lift all 4 wheels off the ground at once, the curb weight doesn't mean anything - are you sure you'll never need to fix a flat on the road when it's loaded? do you want to get a jack that's 'just enough'? get a quality bottle jack with a 5 ton capacity and you'll be able to do most anything needed, anything less is false economy
Bill | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Bill - I don't plan on having all 4 wheels off the ground at once. I'm just thinking of having to change a tire on the road in an emergency. I have an older 4 ton bottle jack that I'll probably just use for my car and get something stronger for the truck like a 5 or 7 ton jack. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Your gross vehicle weight for a 3104 pickup would not be more than 5000 lbs. A 2ton jack would be more than enough to change a wheel/tire.
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I usually lean toward the side of "more is better" when it comes to bottle jacks. it makes me feel a little more comfortable as long as it's not overkill. | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Had to weigh my stock 1959 short bed step side with a 235 in the DMV registration process. It was 3,580 lbs. Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | |
