4 members (78buckshot, Wally / Montana, FishinToms53, klhansen), 57 guests, and 2 robots.
Topics128,053
Posts1,055,778
#1042201 07/13/2014 6:22 PM
Replacing parking brake on 1948 1/2 ton.I am having problem sliding the metal retaining clip at the end of the cable through the cable clamp,i tried spreading the clamp with a flat chisel.It goes about 1/4 of the way through binds.I am afraid if i spread it more it may brake the clamp.Am i wearying to much,or do you force rubber cable through opening on the clamps, any ideas ? thanks
Be careful, your fear of breaking it is correct (I broke one that way). Run an oiled round wire brush through the opening. I have (successfully) used a chisel to slightly/gently spread the edge of the clamp, and then slide in the metal end of the cable.
Yep, you can break them quite easily (I broke both of mine big_eek ). If I remember right, there was a small 'lip' in the middle which corresponded to a small indent in the original cable... I assume to keep it in place.
I had the same problem and luckily avoided breaking the clamps. But, I cannot keep the cable from pulling out of the clamp. The clamp is a smooth bore all the way through.
Actually, I seem to remember grinding down the overall diameter of the metal cable end in order to get it in the clamp...been too long.
