8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#1042625 07/15/2014 3:34 AM
What is different about the front bed cross member which bolts under the bed front, compared to the center cross members?
Carl
I don't recall if the 1st and 2nd cross sill lengths are the same or not (I think they may be identical), but I did verify with Mar-K that the 2nd cross sill is not bolted in. See the last line of paragraph 17. It just sits on the frame with the pad. I was in denial that this would work and the pad would work loose, but everything has stayed together so far.
Not sure if this was your question or not.
Mark-K installation guide
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
The front crossmember has a series of holes drilled in it to bolt up to the front bed panel. The other cross members do not require these holes.
https://www.flickr.com/photos/advance-design_parts_co/8130471047/in/set-72157631884205225
It is these bolts that keep the bottom of the front bed panel from pulling away from the ends of the bed boards.
Along with the bolts Brad mentioned it looks like the pads that the wood blocks sit on are in a different location, looks like they are more in board.
...pic...
Thanks to all!
