2 members (Otto Skorzeny, joe apple), 64 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#1042438 07/14/2014 3:25 PM
V
VEW
Offline
V Offline
I'm not working on my truck (right now), but I am working on my '56 Chevy. I let it sit far too long, so I'm going through it.
I'm installing a new fuel tank, and before I do, I would like to clean out the fuel line from tank to pump. What solution/cleaning agent would you recommend? I have compressed air, so I can blow it out, and I will be installing a filter before the pump. I just would like to get as much varnish/sediment out as possible before I start circulating fresh fuel through the system.
I've already replaced the fuel pump and the engine is running fine on an auxiliary fuel tank.
Thanks for your help.
~ Victor
1957 3100 - moved on
if you really want to clean it out you'll need to remove it and start by soaking, not too spendy to just replace it and much more fail-safe
V
VEW
Offline
V Offline
At times, I just don't know where my brain goes!
That's why it's great to have you guys to bounce things off of.
I will replace the lines.
Thanks Bill.
~ Victor
