6 members (GRNHydra, Greg_H, dunfire, Ponchogl, TPR57C, stlcardinalsguy), 136 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#1041988 07/12/2014 6:44 PM
Can someone tell me what I can use to replace my carter w1 on a 1942 chevy 3/4 truck
Ridge dweller
ridgeview #1041995 07/12/2014 7:21 PM
Why do you want to replace it?
The Carter W-1 was a good looking Carburetor and the ones I have had, were very reliable, and super easy to tear down and or rebuild if need be.
About the only deal breaker is if the Throttle's Butterfly Pivot/Axel has worn the Casting holes really badly so it is sucking in Air there. and I fixed one like that by Brazing then drilling a careful Hole.
Easy enough to get a good used Iron Base if one has one which is too worn out there at the Pivot/Axel Holes.
ridgeview #1042021 07/12/2014 9:34 PM
The standard replacement that GM used was the Rochester B. That is what I have on my truck and I am very happy with it.
1951 1 Ton Completed
ridgeview #1042047 07/13/2014 12:32 AM
The W-1 is a good carb, kits are expensive, but once cleaned and reassembled, it should last a long time. What is wrong with it?
Joe
ridgeview #1042055 07/13/2014 12:59 AM
I ran a Rochester B on my 216 when I first got her on the road and it ran good,than I rebuilt a W1 and went to Kansas city with the W1 got better millage "16 MPG" and some what better performance.I'd stay with the W1.They are harder to rebuild but it' a better carb.
Looks better too.
Pete
ridgeview #1042080 07/13/2014 2:32 AM
Carburetion specialist
(Opinion) the 1941~1948 Carter W-1's used by Chevrolet (483s and 574s) are in the top 5 of all single barrel carbs ever produced anywhere in the world.
Good power, good driveability, good economy, good reliability. What more could you ask for???
If it isn't working properly......fix it!
http://www.thecarburetorshop.com/Carter_W1_service.pdf
Jon.
The Carburetor Shop
ridgeview #1042083 07/13/2014 2:34 AM
62401
This evening I just reinstalled my newly rebuilt W-1 on the Stovebolt "Flagship" -- the '49 3804. Getting back from the test drive, the difference was noticeable.
I sent the carburetor off to Larry Isgro on Long Island. He turned it around very fast (about a week). It's completely rebuilt with new bushings and the works. He even blasted the whole thing and repainted it as original. It really looked beautiful. I had it on my desk here for a day to just admire it ...
At anyrate, I am very pleased with the rebuilt/renewed W-1. Hambone, Peggy and I will be taking a road trip tomorrow in our trucks up to Billy Marlow's (about a 4-hour round trip), but between the 4.10 gearing in the axle and the newly rebuilt carb, I am looking forward to some time in the passing lane smile
Keep the W-1 -- it's a classic carburetor that still gits 'er dun!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
ridgeview #1042101 07/13/2014 4:24 AM
Quote
John,
Is Larry a friend or is he in the carb rebuild business? If so contact info?
Harold
Harold
ridgeview #1042116 07/13/2014 11:02 AM
Authorized Pest
Authorized Pest
P Online: Content
Harold,
(John here, actually) Larry was recommended to me by several people, and I saw him recommended on another forum. This was all after Jon (our own Carbking) told me he had gotten out of the rebuilding business.
Here's his contact info.
Larry Isgro Carburetors Inc
1604 Argyle Rd,
Wantagh, NY 11793
(516) 783-1041
Last edited by Peggy M; 07/13/2014 11:03 AM. Reason: Oops -- Peggy was logged in on this computer
~ Peggy M
1949 Chevrolet 3804
ridgeview #1042118 07/13/2014 11:27 AM
Larry Isgro is a good and reliable carburetor re-builder. He is also a very friendly and helpful fellow to talk with (if he has time to talk).
ridgeview #1042131 07/13/2014 1:07 PM
Just curious, but will the w-1 work on a 54, 235 with an 848 Head? I need a carb for this upgrade, can't find a reasonable yf and I don't want a rochester B. My guess is it will run, if I can get one to fit the manifold but may not be optimal for the engine.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #1042134 07/13/2014 1:18 PM
The W-1 is an S.A.E. size 2 carb. The manifold for a 1954 235 would be drilled for an S.A.E. size 3 carb.
Options:
(A) use an adapter (opinion - looks hokey, but will work)
(B) slot the carb mounting holes (opinion - same as above)
(C) fill the manifold mounting holes, and redrill for size 2.
Jon.
The Carburetor Shop
ridgeview #1042179 07/13/2014 4:52 PM
Thanks Jon, I think I will just keep looking for a yf.
Mike
1946 1-ton Panel
Peggy M #1043426 07/19/2014 2:01 AM
Sent the W1 to Larry also, can;t wait to get it back!
Ridge dweller
ridgeview #1046263 08/01/2014 2:32 AM
Just got my carb back from Larry and could not be more pleased. It was not only rebuilt but was painted and cleaned like new.
Ridge dweller
ridgeview #1046582 08/02/2014 7:15 PM
MikeE, I might have a working CarterYF coming off my fire truck 50GMC 270. Converting over to TBI now . Once I have everything running would part with it. Carter YF 3211, stamped 1697 pn side, D1-786 on butterfly housing, 6-1718 on passenger side.. Jim
ridgeview #1046606 08/02/2014 9:41 PM
Jim,
Thanks for the offer, but I want to keep the manual choke and original oil bath air filter.
Thanks for th offer.
Mike
1946 1-ton Panel
ridgeview #1046775 08/03/2014 7:28 PM
MikeE, mine has both. If interested PM. Jim
ridgeview #1049007 08/12/2014 10:30 PM
Just wanted to let the group know I got my carb W1 back from Larry and my problems have been solved. Great guy and great work, it was even painted as original
Ridge dweller
