1 members (Bucker), 144 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,471
#1038448 06/28/2014 8:47 PM
I got an oakie bushing for my 1946 1/2 ton from Chev;s of the 40,s. Old front bushing removed, leaving rear bushing & old seal in place. When attempting to install the oakie bushing it goes in until the rear raised portion hits the machined step for the old front bushing. I know it is supposed to be a snug fit but several blows with a large hammer & wood block will not advance the bushing.
Any advice? anyone got specific dimensions on the oakie bushings? This is a Canadian truck - anyone know if there are different id's in the Canadian units?
I had the same problem. I learned later that there are two sizes (Diameters). Do some searching around on Stovebolt or check some of the other suppliers. Call them and have them give you the OD's. I got mine part way in and then had to drive it out with a long pipe. It was a real pain. The pipe got stuck because the tube necks down inside.
According to 1929-57 Master parts catalog
1941-50 Outside dimension of the: SEAL, oil, torque tube is: 1 11/16" part # 3691457
So, you would think that the Okie Bushing outer sleeve should be around that dimension.
You could ask these guys Vintage Auto parts I think they make the Okie bushings in house. vapinc.com
This link has some insight also.
Thanks for the input. I got onto the manufacturer via Chev's of the 40's and verified the dimensions were correct. Turned the rear raised portion down by 0.01", froze the bushing, heated the case & it went in ok. Don;t think it will spin but I will drill & pin it like the original bushing to be safe.
I would like to know how you got it out.
1951 1 Ton Completed
I still had 4" sticking out when it jammed the first time. Clamped a bearing splitter behind the forward raised portion. The spitter was drilled & tapped for 3/8 bolts in each half. bolted a piece of angle iron to rhe two bolts, added a middle 3/8" bolt bearing on the drive shaft, tensioned it up and it came loose with a couple of hits on the splitter with a hammer.
Read step number four.
Okie Bushing installation instructions
Do to slight variations in the ID of the drive shaft housings (torque tube).
I guess you kinda have to be a little lucky when your driving it home.
