1 members (Steveoreno),
111
Mod | | | Forums66 Topics128,195 Posts1,057,375 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | I got an oakie bushing for my 1946 1/2 ton from Chev;s of the 40,s. Old front bushing removed, leaving rear bushing & old seal in place. When attempting to install the oakie bushing it goes in until the rear raised portion hits the machined step for the old front bushing. I know it is supposed to be a snug fit but several blows with a large hammer & wood block will not advance the bushing.
Any advice? anyone got specific dimensions on the oakie bushings? This is a Canadian truck - anyone know if there are different id's in the Canadian units? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I had the same problem. I learned later that there are two sizes (Diameters). Do some searching around on Stovebolt or check some of the other suppliers. Call them and have them give you the OD's. I got mine part way in and then had to drive it out with a long pipe. It was a real pain. The pipe got stuck because the tube necks down inside. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | According to 1929-57 Master parts catalog 1941-50 Outside dimension of the: SEAL, oil, torque tube is: 1 11/16" part # 3691457So, you would think that the Okie Bushing outer sleeve should be around that dimension. You could ask these guys Vintage Auto parts I think they make the Okie bushings in house. vapinc.comThis link has some insight also. | | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | Thanks for the input. I got onto the manufacturer via Chev's of the 40's and verified the dimensions were correct. Turned the rear raised portion down by 0.01", froze the bushing, heated the case & it went in ok. Don;t think it will spin but I will drill & pin it like the original bushing to be safe. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would like to know how you got it out. | | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | I still had 4" sticking out when it jammed the first time. Clamped a bearing splitter behind the forward raised portion. The spitter was drilled & tapped for 3/8 bolts in each half. bolted a piece of angle iron to rhe two bolts, added a middle 3/8" bolt bearing on the drive shaft, tensioned it up and it came loose with a couple of hits on the splitter with a hammer. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Read step number four. Okie Bushing installation instructions Do to slight variations in the ID of the drive shaft housings (torque tube). I guess you kinda have to be a little lucky when your driving it home. | | |
