1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#1041784 07/11/2014 11:13 PM
when I park the truck (52 Chev 1/2 ton PU)on any angle to the side, even a slight grade, gas leaks out of the gas cap. I believe it generally occurs when the tank is full. Any way to stop the leak or is it just the nature of the truck?
Green52 #1041787 07/11/2014 11:40 PM
Gas expands as it gets warmer. In warm weather, gas in the ground storage tank is usually cooler than in the truck tank. A full tank of gas could easily expand enough to result in overflow.
tclederman #1041788 07/11/2014 11:46 PM
Stop filling the tank as soon as the pump clicks off the first time. leaves room for expansion.
