0 members (), 83 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
1 Offline
I'm curious about frame shape and dimensions and differences between 1/2 ton and 1 ton on panels?
I was planing on fabricating my engine mount cross member, but if the aftermarket can be used here, I might go for it. As recommended in another topic.
As far as I know front sheet metal was the same.
frame specs can be found in the resto packs, the only difference of panel/burb frames from others is in body mounts .... the aftermarket mount cross members are adjustable to the frame width and after fitting are welded solid [engine mount or trans mount]
3105 and 3805 front sheet metal parts (from doors/seats forward), rear fenders, and rear door/threshold are the same.
1949 Restoration Pack (Chevrolet 1949 Specifications)
body dimensions
frame characteristics
chassis treads and overall widths
1 Offline
I thought so , but was not sure. Thank you guys.
